Root Anytime im in twrp and attempt to reboot system......
xyourxhighnessx
I get warned of my device not having root and im questioned as to whether or not i want to install it (i always click do not install) and the phone reboots to my lock screen like it should and i still have root etc.
I know that rooting required this process of clicking "do not install" after flashing supersu in twrp. Other devices i used required the same process but this is the only one that still keeps asking me if I'd like to install super su because it's not installed.
Is this problem unique to me or is everyone constantly getting prompted everytime they leave twrp?
Not a huge issue to click "do not install" everytime.
Nothing is wrong with anything else ive noticed so really this is minor. Im just curious about what others are experiencing
Try to flash the lastest supersu.zip through twrp recovery reboot and see if it stoped the error
That won't solve anything. For that matter there's no problem. The root that we have on MM is systemless root and TWRP 2.8.7.0 doesn't recognize that. If you flashed the SuperSU zip provided in the how to guide then you're rooted, and if you read that thread you see that you have to ignore that prompt, hit "do not install".
I like the tmobile splash better that the metro...
And none of the tmobile apps rum in the background....
Battery only drains when I have Pandora on ...
Other than that ...use is use...
But it'll stand unused at 100% for a while
