APN help with dun
Nene1251
Hello this is my first post and I need help. Im trying to see if i can put dun into my apn settings(default,mms) but the menu just isn't there for unlimited hotspot. Any workaround? If it possible at all
Hi please tell us your devices make and model and carrier,
Is the device completely stock?
Thanks,
Astr4y4L
Team_Astr4y4L
Thanks,
Astr4y4L
Team_Astr4y4L
My device iaia
Thanks,
Astr4y4L
Team_Astr4y4L
I'm using an lg tribute 5 , version 5.1.1, and I'm on boost Mobile . I also already have my msl code I just cant find where to input dun
My device iaia
Is the device rooted?
I usually modify the file located at.
/system/etc/apns.conf
and add it in there. of course you'd have to have root access to the device to do so...
hope this helps
I've never heard of 'dun', for when setting up an APN. Is it something specific to your carrier, Boost Mobile, and the particular phone you've got?
I've never heard of 'dun'. Is it something specific to your carrier, Boost Mobile, and the particular phone you've got?
it tells the device to allow the apn to use a tether connection for android hotspot.
hope this helps
Would kingroot allow me to do this ? I have it installed I've just been on the fence about rooting . thanks for the help everyone btw
that's a possibility, but i'd recommend soon as you root a device with any of the kingroot/kingo stuff, use something like SuperSUME or something to replace kingroot. after root. because who wants to openly stream their personal info and data to shanghai china or some junk.
LoL
LoL
Lol thanks ill def do that youve been alot of help. So After rooting all i have to do is locate the file and edit it to include dun ? Sorry for making you babysit me through the steps lol just very new to all this
