GLGJing
The most beautiful and powerful System Monitor for Android! Include RAM Booster, Battery Monitor and CPU Monitor. You are able to monitor CPU, RAM, Apps and your Battery at the same time. Powerful System Monitor provides RAM widget, CPU widget and Battery widget. You can monitor the RAM, CPU and Battery information on the home screen very convenient. The detail features including:
1. Monitor the CPU temperature, frequency and usage information
2. Analyze the RAM and Storage usage information
3. Be the RAM Cleaner and boost your phone
4. Show the battery temperature and power information
5. The most important feature is Powerful Monitor can analyze historical data, and you can see the usage information of CPU and RAM. You can also see which applications are consuming the most resources。
Powerful System Monitor is very beautiful and Support multi-theme switching, you can choose the theme you like. if you buy Powerful System Monitor, you will have RAM Booster, Battery Monitor, CPU Monitor at the same time!
Google Play Link: https://play.google.com/store/apps/details?id=com.glgjing.marvel
