Hello, I recently launched a new Calculator on the play store.
It is simple and works like typical physical ones and it is AD-FREE. Also, it uses just a little memory (RAM) usage as it uses (<20 mb mainly) unlike other "popular" calculators that use 70+. It is stable and I have not encounter any crashes yet.
Also, it implements a history panel with any calculations you have made (calculations are stored after you press "=") and next to them there is the date you made them in order to be easier to remember what is for.
It has many customization options, from different thousands/decimal seperators and different languanges ( English, Italian, French, Spanish, Russian, Serbia, Croatian, Greek, Albanian are supported for now ) to different themes to use. More themes and languanges will be added in the future.
It uses internet permissions only for analytics & stats and vibration permissions for click effect.
Any feedback, review, downloads & rates (
) are much appreciated..!!
Link to playstore for more infos and screenshots:
https://play.google.com/store/apps/details?id=com.tzegian.Calculator
PS: If someone wants to help me with translation or has an idea about a beatiful custom theme, I would love to know either here by reply or by pm to discuss and try to match his desire.
I am open to ideas/suggestions and discussion.
