Power Strip is a dock-like home application helps you to take fully advantage of Android multitasking.
I dare not say adapting to this little app "changes everything" of your android usage (iPhone4 does, it changes the way you holding your phone), but it's truly convenient and worth trying.
Developer:
Intuitit
Version:
1.1.5 Asuka (Android 2.1+ compatible)
Function Description:
1. Can be started from any app in any orientation by a single home key click.
2. Access your preferred home screen by double home key clicks.
3. Fast switch to another app, one click to switch back.
4. One click to see all your apps in your current application.
5. Use widgets in your running application without exiting it.
6. Directly share your current application/widget to your friends or visit its market page.
7. Directly uninstall or force stop the running applications without exiting it.
8. Totally customizable.
9. No space limit. You can add ALL your widgets/shortcuts/bookmarks/contacts to it if you wish.
For more information, please check the Power Strip website:
introducing Power Strip
Developer:
Intuitit
Version:
![pstrip-bc.png](http://socket.intuitit.mobi/images/pstrip-bc.png)
![18.jpg](http://socket.intuitit.mobi/images/screenshots/18.jpg)
![32.jpg](http://socket.intuitit.mobi/images/screenshots/32.jpg)
