T
toninoni
Guest
V1.1.8 - N-Body Simulator
It is a pure n-body simulator of particles. An n-body simulator is a system of particles interacting with each other only by means of their gravitational fields moving around freely.
Set up the initial conditions and watch the system evolve while interacting with it. Shoot particles, move the black hole around and also create repulsive forces using the touchscreen. Enable the accelerometer sensor to create a real-world gravity effect!
Features:
-Real n-body simulation, pure gravitational interactions between particles.
-Allow or not phisically realistic collisions and mergers between particles.
-Set particle and background colors.
-Set gravity strength and particle mass.
-Accelerometer support.
-Shoot particles or create repulsive forces using touchscreen.
-Enable the action to expand beyond your screen limits without losing particles.
-Enable or disable the central black hole which exerts a neat attractive force towards the center.
-Enable or disable particle trails (disable to improve performance).
-Modify simulation velocity.
A Live Wallpaper version is also available in the market.
Link to market.
Link to market (live wallpaper).
Some images:
Cheers!
Features:
Link to market.
Some images:
Cheers!
