[APP] Wireless Chief - Save Power And Mobile Data
Another awesome app from Fahrbot
Wireless Chief is an application designed to control the wifi and data radios in your device, as well as many related functions like background data and autosync.
It can be used to save power or minimize data usage, and works either by reading the screen state or on a completely custom schedule.
All data and sync options require root access. There is no other may to manipulate the radios.
Features:
- Turn features on or off depending on screen state
- Disable wifi if no know network is available
- Change wifi scan intervals and scan attempts
- Schedule autosync and background data
- Force autosync on wifi only
If you have any issues, please leave comments in this thread or better yet use the "Write to us" dialog in the application's settings.
Market link:
https://market.android.com/details?id=fahrbot.apps.wirechief&feature=search_result
Screens:
A new release with many improvements - 1.0.8
- New improved UI
- Added active profile selector
- Autosync schedule functions expanded
- Fixed battery profile applying delay
