Hi,are there any Samsung GS III 16 GB International Version owner got App2SD problem like I do? When I try to send apps to SD card by using App 2 SD ( pro or free don't matter ) The app said " The device does not have a real primary external storage, or the primary external storage is emulated. Moving app to SD function may not be supported by this device. "
WTF?! This is a Galaxy S III using ICS 4.0.4 XXLF2 it doesn't support app to SD function? The phone does show the SD card and it's content ( songs,pics from previous phone ) but apps can't be moved there.
When I google it I've seen a lot of people got the same issue but no ones able to provide anwers.
So now I can only use the build in 16 GB. Can some one help to answer this if you know the reason why.
Thanks in advance
Thanks in advance
