I bought new Tablet 8" from China with Android 10. I installet aplication - apk, got icon on a screen but when tried to lunch - nothing happend. I got a log for that. may be you can explain me what is wrong -my tablet or android version and is it possible to fix. about application I have installed - it works on Android from Version 7 to 11-from manufacturer.
Log for this:
2022-11-06 22:26:43.768 7212-7212/? E/AndroidRuntime: FATAL EXCEPTION: main
Process: com.diagzone.pro.v2
5c59d0e679d292c93e8c7dc1, PID: 7212
java.lang.ExceptionInInitializerError
at java.lang.reflect.Constructor.newInstance(Native Method)
at java.lang.Class.newInstance(Class.java:1606)
at android.app.Instrumentation.newActivity(Instrumentation.java:1071)
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2416)
at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2601)
at android.app.ActivityThread.access$800(ActivityThread.java:178)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1470)
at android.os.Handler.dispatchMessage(Handler.java:111)
at android.os.Looper.loop(Looper.java:194)
at android.app.ActivityThread.main(ActivityThread.java:5648)
at java.lang.reflect.Method.invoke(Native Method)
at java.lang.reflect.Method.invoke(Method.java:372)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:960)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:755)
Caused by: java.util.regex.PatternSyntaxException: Syntax error in regexp pattern near index 8:
^\s*(?<num>(?<int>\d+)?\.?(?<fract>\d*)?)\s*(?<type>[a-zA-Z]+)?\s*$
at java.util.regex.Pattern.compileImpl(Native Method)
at java.util.regex.Pattern.compile(Pattern.java:411)
at java.util.regex.Pattern.<init>(Pattern.java:394)
at java.util.regex.Pattern.compile(Pattern.java:381)
at com.diagzone.x431pro.activity.ProtectedGDApplication$WebTXActivity$d.<clinit>(Unknown Source)
... 14 more
thanks.Maks
Log for this:
... 14 more
thanks.Maks
