Apps to tell battery capacity
Recently replaced factory battery with a QCell 4100mah battery. So far haven't noticed any difference between the two. The new battery says it is 4100mah, and it is definitely bigger size-wise than my old one. I'm wondering if I just got ripped off though and this battery actually has the same capacity that the factory one did, they just label it as 4100mah. I downloaded the app "Battery Monitor Widget" and clicked Calibration. In the Estimated field it consistently says ~1530mah. Is that the battery capacity? Is there another app that will tell me that? Just trying to figure out if I got ripped off or why there is no difference between the "4100"mah battery and the 1800 factory battery. Thanks for any help!
