Help Archos 101 G9 android problem
MarioLaul
Such a concern that I wanted to make a formation Arcohs 101 G9 Tablet PC. I went to the Archos A101S Recovery Menu by holding down the volume + button and switch the power on button. Its a stupid mistake I selected from the Format System-> Device Reformat. Of course I did not know that before the computer to connect and integrate the Archos firmware file to the root folder. Android is removed?, at least it does not Boot up your computer as well, and does not connect, what to do?
Hi...im stuck in A101S recovery Mode, i'm unable to mount my Archos 101 G9 Turbo...can anyone help with this please....
Hello people on the internet, have you solved the problem yet? Because I'm in a same situation, where my Archos 101 G9 Turbo tablet constantly boots into Archos A101S Recovery Menu by holding down the up volume with the power button, therefore I got into the "Recovery Mode" and pressed this Format System>Reformat Device... But i just wanted to Format the device so its able to be used like new, but I didn't know that you would need to connect the computer, therefore as I always try to turn the system on, it constantly boots into Archos A101S Recovery Menu although I'm not holding any volume keys. PLEASE READ THIS AND REPLY ASAP YOU KNOW HOW TO FIX THIS PROBLEM...
regarding
Maksim Belodedov
