Help Are non-Motorola earphones with built-in microphone compatible?
cdl
Hi all,
do you know if non-Motorola earphones with builtin microphones are compatible with the Milestone?
There are many such earphones meant for the Iphone, like
Sennheiser UK - MM 80i Travel
but I can't understand if they would work with the Milestone.
Thanks!
No one will be able to answer probably unless they tried the headset. You can always try and see if it works and if it does not just return it. I bet your country has some kind of distance sales law allowing you to return the product within specified time.
