(ASAP HELP) Used Kingo Root, got stuck and unplugged.
Cheerioats
Wanted to root my v. 5.0.2 at Samsung Galaxy Tab S (SM-T805), and decided to root it with Kingo Root.
I plugged it into my PC, and the process went well, as I could see. I also checked before that my device could be safely rooted. It stuck at 99% with the message "Waiting for device...".
My device was in Download Mode, (green Android-man, Downloading..., Do not turn off target!!), and I found no other way. I unplugged it, but now I can't exit out of that screen.
Help!
Not sure if it will help but you should be able to press and hold the power button till it reboots. Hopefully it will boot into a working system.
