Asteroid Smart and second 7 tablet for media and Apps
Britjoe
So the Parrot Asteroid Smart is great for answering phone Calls,
The Radio & Media interface is Awesome the swipe screen function for volume up and down and track forward back is great. but even while the device is rooted the and the play store works but the headunit it self is very low on resources,
Also where it is mounted on in my dash makes it awkward or dangerous to use while driving, the head unit also has the capacity for 4 usb in puts that you can run usb hubs on each so the amount of media you can load on the system is infinite.
So Ive added another Android 7 inch tablet higher on the dash, its a Acer one B1 770, Ive rooted that and have it auto suspend on ignition off.
Heres a few of the Apps Ive installed
Autosleeper Auto power ON-OFF
https://play.google.com/store/apps/details?id=com.as.powerchecker&hl=en
DashCommand (OBD ELM App)
https://play.google.com/store/apps/details?id=com.palmerperformance.DashCommand&hl=en
Battery Widget by Lazy Hero Productions
https://play.google.com/store/apps/details?id=de.lazyheroproductions.batterywidget&hl=en
Audio Glow Music Visualizer
https://play.google.com/store/apps/details?id=com.cyphercove.audioglowfs&hl=en
Poweramp Full Version
https://play.google.com/store/apps/details?id=com.maxmpz.audioplayer.unlock&hl=en
Offline maps & Navigation
https://play.google.com/store/apps/details?id=cz.aponia.bor3.offlinemaps&hl=en
These are just some of the apps ive used and are happy with, ive tried a few launchers and really not happy with any of them so far.
With hind site I probably gone with a Samsung or Nexus tablet but compared to the specs of the 700 dollar Asteroid Smart the Acer tablet rocks, the sound through Blue tooth is great and has lots of bottom end and mid-range, It tethers to my home WiFi when I pull into my driveway or if im out and about I can quick toggle it to my G4.
Any suggestions would be appreciate it Thanks
