Dai_the_flu
Hi all,
I am new to android and am completely puzzled by AsyncTasks. I need to create a leaderboard which will pull global leaderboard scores from a server.
I have posted below the two methods that were created in the LeaderboardsFragment which are used to access and display the scores. I am unsure of how to use these in the AsyncTask - mostly how and what parameters to pass to the AsyncTask. Any hints would be appreciated, i've been stuck on this for a while.
public void getGlobalScores() {
//gets global score in HTML format to be parsed
StrictMode.ThreadPolicy policy = new StrictMode.ThreadPolicy.Builder().permitAll().build();
StrictMode.setThreadPolicy(policy);
try {
URL url = new URL("http://62.254.134..............");
HttpURLConnection con = (HttpURLConnection) url.openConnection();
readStream(con.getInputStream());
} catch (Exception e) {
e.printStackTrace();
//used by the network connect to get or send highscore information
//Not much should change in here with regex wise etc, but as it gets the data and stores the global scores in a lovely 2d array
//it then displays to screen
public void readStream(InputStream in) {
BufferedReader reader = null;
try {
StringBuilder htmlIn = new StringBuilder();
StringBuilder globalScoreBuilder = new StringBuilder();
htmlIn.append("");
reader = new BufferedReader(new InputStreamReader(in));
String line = "";
while ((line = reader.readLine()) != null) {
htmlIn.append(line);
// String to be scanned to find the pattern.
String html = htmlIn.toString();
String regexPattern = "<td align=\"left\" style=\"padding-left:10px;\">(\\d+?)</td>|<td align=\"right\" style=\"padding-right:10px;\">(\\w+?)</td>";
// Create a Pattern object
Pattern patternObject = Pattern.compile(regexPattern);
// Now create matcher object.
Matcher matcherObject = patternObject.matcher(html);
Log.d(getActivity().getResources().getString(R.string.LOG_TAG), "Trying to find regex matches");
TopScores.append("\n");
int nextFreePointer = 0;
int rowCount = 0;
while (matcherObject.find()) {
if (matcherObject.group(1) != null) {
Log.d(getActivity().getResources().getString(R.string.LOG_TAG), "Regex match : " + matcherObject.group(1));
globalScoreBuilder.append(matcherObject.group(1) + " ");
global_scores[rowCount][nextFreePointer] = matcherObject.group(1);
nextFreePointer++;
if (matcherObject.group(2) != null) {
Log.d(getActivity().getResources().getString(R.string.LOG_TAG), "Regex match : " + matcherObject.group(2));
globalScoreBuilder.append(matcherObject.group(2) + " ");
global_scores[rowCount][nextFreePointer] = matcherObject.group(2);
nextFreePointer++;
if (nextFreePointer > 2) {
rowCount++;
globalScoreBuilder.append("\n");
StringBuilder sb = new StringBuilder();
String lineSeparator = System.getProperty("line.separator");
for (String[] row : global_scores) {
sb.append(Arrays.toString(row)).append(lineSeparator);
String text = sb.toString();
TopScores.append("Global Top 10 Scores\n");
TopScores.append(text);
} catch (IOException e) {
} finally {
if (reader != null) {
try {
reader.close();
public class AsyncOperation extends AsyncTask<String, Void, Void>{
protected void onPreExecute(){
Log.d("PreEx", "Im now in PreExecute");
}//end of onPreExecute
@override
protected Void doInBackground(String... params) {
}//doinBackground
protected void onProgressUpdate(Void... values){
}//onProgressUpdate
protected void onPostExecute(Void... result){
}//end of onPostExecute
}//end of AsyncOperation inner class
}//end of Leaderboards class
try {
try {
htmlIn.append("");
String line = "";
int rowCount = 0;
nextFreePointer++;
nextFreePointer++;
rowCount++;
} finally {
try {
reader.close();
@override
}//doinBackground
}//onProgressUpdate
