AT&T Moto X to T-Mobile
seagood3
I am looking to buy a AT&T Moto X from a friend. Will I be able to switch this over to T-Mobile without any problems and be able to access all of the bands on T-Mobile.
I have read other threads, but seem to get different answers. Any help is much appreciated.
Thanks.
It will likely be SIM locked to AT&T, which would prevent you from using it on T-Mobile. Also, as far as frequencies go, it supports most bit not all of T-Mobile's frequencies. The only one it doesn't is the 1700/2100 (band 4) hspa. Everything else though should be fine assuming you get AT&T to sum unlock it for you.
