Root [AT&T] S3 hyperdrive rom help
chevyman1
I install hyperdrive rom yesterday and my camera stops every time I open it. And the flashlight don't work. Says camera is in use by another application. Can anyone tell me what to do to fix it? Other than that it's great. Thanks
Have you checked to see if those were known bugs in the rom?
It doesn't say anything about it. It has a couple different cameras to install like 4.2 camera. I wouldn't see why it dont work
Typically I see this with either a bad download or not a full wipe.
The md5sum for the zip is: 00acb804072602c91c685f4baadad9d0
Check and make sure that this checks out. Also, did you wipe your /data, /system, cache, and and dalvik cache, before flashing?
In ES File Explorer, long tap the zip file. Hit the 3-dot menu button in the bottom-right. Third option up is Properties. Bottom option is Show checksum.
