These are current as of November 6, 2012. I have 2 APN's setup in my TELUS Samsung Galaxy S3.
This is the one selected (along with its info):
APN: sp.telus.com
Proxy: <Not set>
Port: <Not set>
Username: <Not set>
Password: <Not set
Server: <Not set>
MMSC: http://aliasredirect.net/proxy/mmsc
MMS Proxy: 74.49.0.18
MMS Port: 80
MCC: 302
MNC: 220
Authentication type: None
APN type: internet + mms
APN protocol: IPv4
Enable/disable APN: APN enabled (check marked)
Bearer: Unspecified
Here is the second APN in my phone (I'm not using this one, as it wasn't selected by default):
APN: isp.telus.com
Proxy: <Not set>
Port: <Not set>
Username: <Not set>
Password: <Not set
Server: <Not set>
MMSC: <Not set>
MMS Proxy: <Not set>
MMS Port: <Not set>
MCC: 302
MNC: 220
APN type: dun
APN protocol: IPv4
Bearer: Unspecified
I thought I'd post to keep the info available for posterity's sake
(and, you never know... if I update from my stock rooted ROM, I'll probably need these settings somewhere).
APN: sp.telus.com
Proxy: <Not set>
Port: <Not set>
Username: <Not set>
Password: <Not set
Server: <Not set>
MMS Port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
Bearer: Unspecified
APN: isp.telus.com
Proxy: <Not set>
Port: <Not set>
Username: <Not set>
Password: <Not set
Server: <Not set>
MMSC: <Not set>
MMS Port: <Not set>
MCC: 302
MNC: 220
APN type: dun
APN protocol: IPv4
Bearer: Unspecified
