Audible files have DRM on them. You might consider removing the DRM from the files before uploading them to Dropbox, or if you have a MicroSD slot on your phone, you can use the Audible app from the Play Store and store your audiobooks there.
It's DRM on Audible audiobooks. You'll have to find a way to remove it. Can't really help you with that here as it's illegal and against forum rules. You can stream your books straight from Audible if you don't wish to store them locally, using their app, no need for Dropbox.
