Audio amplification and EQ
JamOnIt
Are there any add-on audio EQs that will work on your entire phone (i.e. music player, Slacker, Pandora)? I've heard the recent Beats port can do something similar, but I've also heard it can wreak havoc on some phones.
Ideas?
You could look at Volume+. It works for some phones if they are not rooted, but I believe it works on any rooted phone.
Hi...is there any method can measure the input (voice) and the output after amplify through EQ (write out as wave) for the decibel <db>?
I believe DSP manager or EQ app does this. DSP apk it's over at XDA. EQ it's at the market...or should I say at "play".
Ideas?
+1 for DSP manager. I used to use EQ apps from the market until I found that app. DSP Manager is the best, IMO.
Hello , You now decide for music , i've Huawei Y5 2017 and want something for Videos , Sound of any Videos is low and not because of videos because not all videos has same sound degree , i want something help can you ? or any technical professional could help me , will be favor from you guys , thnx .
