Help Audio crackle (d2att/oem touchwiz)
jonklaus
I have a chronic audio problem with an S3, only when running the oem touchwiz interface. With various other Roms, the audio works perfectly, so it's clearly not a hardware issue. I've been searching for a solution here and elsewhere, but have yet to find one.
The problem is a crackling sound through the default music player and other audio applications. Third party audio applications work fine, but I would like to be able to use both touchwiz and the default apps if possible.
Thanks!
