Help audio files problems... little help
rortiz76
I have a galaxy s3 at&t version with jelly bean ..., and i have proble whith music player wont play some formats like mpga ... i need to convert it to have it in playlist...
Someone can help me to know if i doing something wrong?
There are a number of programs that can convert sound files from one format to another. You can simply move the file to your PC, do the conversion and then move it back to your phone. I'll have to wait until I get home to let you know which program I use. I haven't used it in a while.
You can also do a Google search for it.
Yes thanks you for the info i use one in my pc and phone to but ... the question is why cannot read it if other android phones do, because i am thinking the update its the problem i dont know....
Because if you try to find the audio file in the memory and you press it its sound but when you look in the music player dont added and never find it...
Thanks anyway for your help lets see if somebody else know about it...
