AudioRecorder not recording right
amirihana
I am trying to use AudioRecorder to record a wav file for a certain interval of time (corresponding to a certain number of samples). to stop the recording i used Timer().schedule(delay) to stop after a while. but no matter what is the value of that delay the file is always the same size, and not readble.
Code:
public class Record extends Activity {
private static final int RECORDER_SAMPLERATE = 44100;
int compt=0;
int duration=1;
//int numSample= duration*RECORDER_SAMPLERATE;
private static final int RECORDER_CHANNELS = AudioFormat.CHANNEL_IN_MONO;
private static final int RECORDER_AUDIO_ENCODING = AudioFormat.ENCODING_PCM_16BIT;
private AudioRecord recorder = null;
private volatile Thread recordingThread=null;
private volatile boolean isRecording = false;
int bufferSize = AudioRecord.getMinBufferSize(RECORDER_SAMPLERATE,RECORDER_CHANNELS, RECORDER_AUDIO_ENCODING);
long mySubChunk1Size = 16;
short myBitsPerSample= 16;
int myFormat = 1;
int myChannels = 1;
long myByteRate =RECORDER_SAMPLERATE* myChannels * myBitsPerSample/8;
int myBlockAlign = myChannels * myBitsPerSample/8;
Handler handler;
String filePath = Environment.getExternalStorageDirectory().getAbsolutePath()+"/recordedSound"+compt+".wav";
DataOutputStream dd;
@Override
public void onCreate(Bundle savedInstanceState)  {
    setContentView(R.layout.activity_raw_rec);
    try
        try {
            startRec();
        } catch (IOException e) {
            // TODO Auto-generated catch block
            e.printStackTrace();
        new Timer().schedule(new TimerTask()
            @Override
            public void run()
                recordingThread.interrupt();
                isRecording=false;
                recorder.stop();
                recorder.release();
                recorder = null;
        ,5000); //execute after 5 seconds of recording
    }//end try
    catch(IllegalStateException e) {
private void startRec() throws IOException{
    recorder = new AudioRecord(MediaRecorder.AudioSource.MIC,RECORDER_SAMPLERATE, RECORDER_CHANNELS,RECORDER_AUDIO_ENCODING, bufferSize);
    recorder.startRecording();
    isRecording = true;
    recordingThread = new Thread(new Runnable() {
        public void run() {
            writeToFile();
    }, "AudioRecorder Thread");
    recordingThread.start();
private void writeToFile() {
    // Write the output audio in byte
    byte[] data= new byte[bufferSize];
    while (isRecording) {
        try{
            recorder.read(data, 0, bufferSize);
            Log.d("recorder value", "value"+recorder);
        catch (NullPointerException e)
        try {
            // // writes the data to file from buffer
            // // stores the voice buffer
            dd=new DataOutputStream( new FileOutputStream(filePath));
            dd.writeBytes("RIFF");
            dd.writeInt(0); // Final file size not known yet, write 0
            dd.writeBytes("WAVE");
            dd.writeBytes("fmt ");
            dd.writeInt(Integer.reverseBytes(16)); // Sub-chunk size, 16 for PCM
            dd.writeShort(Short.reverseBytes((short) 1)); // AudioFormat, 1 for PCM
            dd.writeShort(Short.reverseBytes( (short) myChannels));// Number of channels, 1 for mono, 2 for stereo
            dd.writeInt(Integer.reverseBytes(RECORDER_SAMPLERATE)); // Sample rate
            dd.writeInt(Integer.reverseBytes( (RECORDER_SAMPLERATE*myBitsPerSample*myChannels/8))); // Byte rate, SampleRate*NumberOfChannels*BitsPerSample/8
            dd.writeShort(Short.reverseBytes((short) (myChannels*myBitsPerSample/8))); // Block align, NumberOfChannels*BitsPerSample/8
            dd.writeShort(Short.reverseBytes( myBitsPerSample)); // Bits per sample
            dd.writeBytes("data");
            dd.write(data);
            //dd.close();
Well used this code:
recorder.setAudioSource(MediaRecorder.AudioSource.MIC);
recorder.setOutputFormat(MediaRecorder.OutputFormat.THREE_GPP);
recorder.setAudioEncoder(MediaRecorder.AudioEncoder.AAC );
// recorder.setMaxDuration(50000); // 50 seconds
recorder.setAudioEncodingBitRate(160 * 1024);
//recorder.setAudioChannels(2);
recorder.setOutputFile(path+audioname );
or you may see a complete tutorial http://programondaspot.blogspot.com/2015/06/hi-guys-now-i-want-to-show-you-how-to.html
