Help Auto-brightness vs low brightness?
D
Deleted User
Guest
I generally use auto-brightness because I figured it would be easier on battery because the screen is no brighter than it needs to be.
But I have now been wondering if the sensor itself, constantly checking brightness levels, ends up using just as much battery?
I do also have a slight issue where under certain lighting, the sensor seems to struggle to gauge brightness and keeps lightening and darkening.
So if I used the power widget and put the brightness on it's lowest setting (which at this moment in time is slightly brighter than it is being set by auto-brightness) would that use any more or any less than auto?
Low brightness is always better than auto brightness
Edit-the widget low setting isn't truly low. Go into your display settings and change it there.
Yea I found I can do with the brightness a fair bit lower than the power widget sets it.
Hmm, anyone know of an app that can put a brightness control slider into the notification pull-down?
I would be very surprised of there wasnt a root option for it like so
My pull down menu on my EVO 4G lte
