[FONT="]DISCLAIMER: I AM NOT RESPONSIBLE FOR ANY DAMAGES/BRICKING THAT OCCURS TO YOUR DEVICE.
[/FONT][FONT="]For starters i should say I didnt build this port someone else did i just found the ROM and it needs work.
[/FONT][FONT="]
[/FONT][FONT="]I am willing to work on this ROM but I need testers I am getting a new phone but i will keep this one as long as somebody tests it, so Backup and get ready to test.[/FONT]
2.Wipe Data/Factory Reset
3. wipe cache partition
5. Scroll to Advanced
6.Wipe Dalvik cache
7.Install zip from sd card
8.Choose Rom to install
9.Install Gapps
10.Reboot[/FONT]
-Wipe Data/factory reset
-wipe cache partition
-wipe dalvik
- format data
- format system
- format cache
-install ROM
-install gapps
-Go to advanced
-fix permissions
let me know if this helped.
The link to recieve the cm11 ROM for those interested in testing is(Confirmed Not Working...For the moment):https://docs.google.com/file/d/0B0yJCiUYmg-3MTVWb25lUEtuWjQ/edit?pli=1
CM11 Tester 1 (Confirmed Boot looping):CM11-UNOFFICIAL-Test 1-Z992-4.26.14 - Download - 4shared
CM11 Tester 2 (Status 7 error in CWM);CM11-UNOFFICIAL-Test 2-Z992-4.26.14 - Download - 4shared
[/FONT]
CM11 Tester 3 (Status 6 Error in CWM):CM11-UNOFFICIAL-Test 3-z992-4.26.14 - Download - 4shared
[FONT="]CM11 Tester 4 (Rewrote Update Script)[/FONT]: CM11-UNOFFICIAL-Test 4-Z992-4.26.14 - Download - 4shared
[FONT="]The forum i found it on is: [Request] Zte Avail 2 - Device Requests - CyanogenMod Forum
The Gapps For the Cm11 ROM (Cant gaurantee it will work with the Avail 2):Google Apps – CyanogenMod
P.S. I've downloaded the ROM to Disect it but i need a tester to tell me whats wrong ith it if anyone does this can you make a video too.
Thanks.
Give Thanks To The Developers (Looking For More To Help)
[/FONT]Amalloggi (me)
DirtyRyada
[FONT="]
Give Thanks To The Testers[/FONT] (Also, Looking For More)[FONT="]
Redneckrocketeer
Mel4787
DirtyRyada
Please PM me for any issues dont post them on the thread.
Thanks!!
This ROM is No Longer being supported if someone else wants to take over go for it.
[/FONT][FONT="]
[FONT="]How To Flash (For Newbs)[/FONT]
[FONT="]!. Boot Into CWM Recovery2.Wipe Data/Factory Reset
6.Wipe Dalvik cache
9.Install Gapps
10.Reboot[/FONT]
[FONT="]The Rom:[/FONT]
[FONT="]This ROM is a ported Cm11 ROM from the Sony Xperia Tipo. problems i've heard about it are Cyanogenmod Account Stops working and Wifi/Cell/Data doesn't work. if anyone knows how to fix this let me know. but a fix that might work is-Wipe Data/factory reset
-wipe dalvik
- format data
- format system
- format cache
-install ROM
-install gapps
-Go to advanced
-fix permissions
[/FONT]
Thanks.
DirtyRyada
[FONT="]
Redneckrocketeer
Mel4787
DirtyRyada
Thanks!!
