My android virtual device not load. I am using API_27 with hardware GLES 2.0. It is running on vmware ubuntu 16.04. Ram size is 4gb.
Here is a paste bin of the logcat after it has been loading for 1 hour - https://pastebin.com/YYucCtKE. After around 1 hour it crashed.
**Event Log**
12/14/17
12:00 PM Emulator: context mismatch in svga_sampler_view_destroy
12:00 PM Emulator: VMware: vmw_ioctl_command error Invalid argument.
12:00 PM Emulator: Process finished with exit code 134 (interrupted by signal 6: SIGABRT)
**Some Logcat Errors:**
Unrecognized GLES max version string in extensions: ANDROID_EMU_CHECKSUM_HELPER_v1 ANDROID_EMU_dma_v1
12-14 10:52:20.828 1380-1383/? E/vold: Failed to chmod /data/system_ce/0: No such file or directory
12-14 10:52:20.829 1380-1383/? E/vold: Failed to chmod /data/misc_ce/0: No such file or directory
12-14 10:52:20.840 1380-1383/? E/vold: Failed to chmod /data/media/0: No such file or directory
12-14 10:52:35.630 1522-1540/? E/vndksupport: Could not load /vendor/lib/egl/libGLES_emulation.so from sphal namespace: dlopen failed: library "/vendor/lib/egl/libGLES_emulation.so" not found.
12-14 11:48:08.609 1424-1907/? E/EffectsConfig: Failed to parse /vendor/etc/audio_effects.xml: Tinyxml2 error (3): /vendor/etc/audio_effects.xml (null)
12-14 11:48:08.612 1424-1907/? E/EffectsFactoryConfigLoader: Failed to parse XML configuration file
12-14 11:48:08.637 1424-1907/? W/EffectsFactory: Failed to load XML effect configuration, fallback to .conf
12-14 15:14:01.090 11719-11719/? A/DEBUG: *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
12-14 15:14:01.198 11719-11719/? A/DEBUG: Build fingerprint: 'google/sdk_gphone_x86/generic_x86:8.1.0/OSM2.171116.002/4458339:userdebug/dev-keys'
12-14 15:14:01.199 11719-11719/? A/DEBUG: Revision: '0'
12-14 15:14:01.210 11719-11719/? A/DEBUG: ABI: 'x86'
12-14 15:14:01.240 11719-11719/? A/DEBUG: pid: 11676, tid: 11676, name: zygote >>> zygote <<<
12-14 15:14:01.299 11719-11719/? A/DEBUG: signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
12-14 15:14:01.319 11719-11719/? A/DEBUG: Abort message: 'heap.cc:438] Check failed: region_space_mem_map != nullptr No region space mem map'
12-14 15:14:01.320 11719-11719/? A/DEBUG: eax 00000000 ebx 00002d9c ecx 00002d9c edx 00000006
12-14 15:14:01.361 11719-11719/? A/DEBUG: esi ad3d9000 edi 00002d9c
12-14 15:14:01.397 11719-11719/? A/DEBUG: xcs 00000073 xds 0000007b xes 0000007b xfs 00000000 xss 0000007b
12-14 15:14:01.399 11719-11719/? A/DEBUG: eip b1ca0ac4 ebp cb1f9ecb esp bff54998 flags 00000286
12-14 15:14:01.610 11719-11719/? A/DEBUG: backtrace:
12-14 15:14:01.678 11719-11719/? A/DEBUG: #00 pc 00000ac4 [vdso:b1ca0000] (__kernel_vsyscall+16)
12-14 15:14:01.681 11719-11719/? A/DEBUG: #01 pc 0001edf8 /system/lib/libc.so (syscall+40)
12-14 15:14:01.829 11719-11719/? A/DEBUG: #02 pc 0001f073 /system/lib/libc.so (abort+115)
12-14 15:14:01.840 11719-11719/? A/DEBUG: #03 pc 0054d4eb /system/lib/libart.so (art::Runtime::Abort(char const*)+603)
12-14 15:14:01.880 11719-11719/? A/DEBUG: #04 pc 0011fb23 /system/lib/libart.so (_ZNSt3__110__function6__funcIPFvPKcENS_9allocatorIS5_EES4_EclEOS3_+35)
12-14 15:14:01.901 11719-11719/? A/DEBUG: #05 pc 0065f26b /system/lib/libart.so (android::base::LogMessage::~LogMessage()+1051)
12-14 15:14:01.917 11719-11719/? A/DEBUG: #06 pc 0027a97d /system/lib/libart.so (art::gc::Heap::Heap(unsigned int, unsigned int, unsigned int, unsigned int, double, double, unsigned int, unsigned int, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char>> const&, art::InstructionSet, art::gc::CollectorType, art::gc::CollectorType, art::gc::space::LargeObjectSpaceType, unsigned int, unsigned int, unsigned int, bool, unsigned int, unsigned int, bool, bool, bool, bool, bool, bool, bool, bool, bool, bool, bool, unsig
12-14 15:14:01.918 11719-11719/? A/DEBUG: #07 pc 0055066d /system/lib/libart.so (_ZN3art7Runtime4InitEONS_18RuntimeArgumentMapE+10413)
12-14 15:14:01.919 11719-11719/? A/DEBUG: #08 pc 00554808 /system/lib/libart.so (art::Runtime::Create(std::__1::vector<std::__1:
air<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char>>, void const*>, std::__1::allocator<std::__1:
air<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char>>, void const*>>> const&, bool)+184)
12-14 15:14:01.929 11719-11719/? A/DEBUG: #09 pc 0039ace7 /system/lib/libart.so (JNI_CreateJavaVM+647)
12-14 15:14:01.940 11719-11719/? A/DEBUG: #10 pc 000044ae /system/lib/libnativehelper.so (JNI_CreateJavaVM+46)
12-14 15:14:01.959 11719-11719/? A/DEBUG: #11 pc 00077d5d /system/lib/libandroid_runtime.so (android::AndroidRuntime::startVm(_JavaVM**, _JNIEnv**, bool)+7581)
12-14 15:14:01.960 11719-11719/? A/DEBUG: #12 pc 0007823b /system/lib/libandroid_runtime.so (android::AndroidRuntime::start(char const*, android::Vector<android::String8> const&, bool)+395)
12-14 15:14:01.969 11719-11719/? A/DEBUG: #13 pc 00001db2 /system/bin/app_process32 (main+1602)
12-14 15:14:01.970 11719-11719/? A/DEBUG: #14 pc 000b69e4 /system/lib/libc.so (__libc_init+100)
12-14 15:14:02.040 11719-11719/? A/DEBUG: #15 pc 000016cd /system/bin/app_process32 (_start_main+80)
12-14 15:14:02.049 11719-11719/? A/DEBUG: #16 pc 000016d8 /system/bin/app_process32 (_start+10)
12-14 15:14:02.060 11719-11719/? A/DEBUG: #17 pc 00000004 <unknown>
12-14 15:14:02.079 11719-11719/? A/DEBUG: #18 pc 00020b97 <anonymous:bff37000>
12-14 15:14:08.048 11719-11719/? E/crash_dump32: unable to connect to activity manager: Connection refused
12-14 15:14:08.057 1574-1574/? E//system/bin/tombstoned: Tombstone written to: /data/tombstones/tombstone_01
**Event Log**
12/14/17
![Stick Out Tongue :p :p](/styles/smilies/google/stickouttongue.png)
