awd_launcher dock row help!!!
Mikesnap
Member
Ok so i put the icons/apps down there and started putting apps on the home screen. Eventually it says esktop is full when there is still like 5 spots and starts moving my icons on the dock on the bottom off the screen 1 by 1 for every shortcut more i put on the home screen.
Can anyone please please tell me how to fix this its really driving me nuts
Hey there Mikesnap,
I'm surprised you haven't gotten a response yet. I mentioned this issue over on the ADW forum -- whatever's listed in the Market page -- and learned that this is a known problem. Fortunately, there's a quick fix: rotate your screen 90 degrees to landscape view, then back again, and you should be in good shape. Does that help?
