ivanzorkic
Member
This has been brought up before, but I was unable to find a satisfying answer. And I know it's a newbish question.
What is the difference between exiting an app with the back button compared to the home button? I am not talking about switching to the home screen, I am talking about a scenario when you want to exit an app. For example, you play a game, you're done - do you press home or back? Or, you're in the Facebook app and you want to exit to the homescreen - what do you press - back or home? At first, I thought both buttons do the same with the difference that home brings you to the homescreen instantly while back goes through your previous steps/pages/screens in the current app and then returns you the homescreen.
But later I noticed that 'reactivating' some apps that were exited via the back button cause them to 'reload' (the loading screen shows up - with certain games, grooveshark's loading screen, etc.) while they switch back instantly when "exited" with the home button.
I gather the way to 'leave' an app you don't plan on using for at least a short while (I am not talking about closing the app, I know it's up to Android, or some task-killer) is the back button, while home is more for task switching/starting new apps while old ones are running.
Am I correct? What is the common practice?
