Hi,
Samsung Galaxy S, PDA:JPA/PHONE:JPP/CSC:JP7 (VDI)
Kies 2.0.0.11014_49
Windows 7 Ultimate (32bit)
Fedora 14 (32bit) [no Kies]
I tried to raise the same issue with both Vodafone (Ireland) and Samsung. Haha... Those people who replied have not clue what I was talking about. Both companies asked me to send the mobile to them
Basically lammers. I asked them to pass this to their developers, but they also does not understand the word "escalation"
I do not believe Samsung developers do not read those posts. That would prove their lack of interest.
I tried to troubleshoot the issue a little bit myself, but not great results. I believe the issue is somewhere in between the Kies drivers and contacts database.
Phone after a fresh restart.
Settings > Wireless and Network > USB settings > Ask on connection
After few connections with PC:
1. Phone switches to and displays Car mode in Notifications area.
2. Screen turns to landscape.
3. Kies does not connect and Windows does not see the phone storage.
Settings > Wireless and Network > USB settings > Mass storage
After few connections with PC eventually you can get "USB mass storage" prompt on the phone and phone storage will apear and can be mounted.
Changed back to Settings > Wireless and Network > USB settings > Ask on connection
After connecting a USB cable got "Select USB mode".
Selected Samsung Kies. Kies lanuched and got MTP Application Connected on the phone.
Phone appeared eventually and connected in Kies.
Clicked contacts and got nothing, but noticed Windows Auto-run window. Changed all the options for GT-I9000 to "No action" and closed the promped.
Now in contacts I get "No response from the device..." error message. Clicked OK. Contacts in Kies stay blank.
From Kies also:
Tried to export Contacts and got "Device not responding" error.
Tried to export Schedule and got "Device not responding" error.
Tried to export Memo and got "There is not Memo available to transfer" message.
Tried to backup Contacts and got the error and blank Contacts page again.
"An unexpected error prevented the data from backijng up" when tried to backup with Kies.
When trying to connect in Fedora 14 as a USB mass storage I got this:
[ 383.229028] usb 4-1: new low speed USB device using uhci_hcd and address 2
[ 383.292075] hub 4-0:1.0: unable to enumerate USB device on port 1
[ 385.357029] usb 4-1: new low speed USB device using uhci_hcd and address 3
[ 385.419086] hub 4-0:1.0: unable to enumerate USB device on port 1
[ 386.456029] usb 4-1: new low speed USB device using uhci_hcd and address 4
[ 386.518064] hub 4-0:1.0: unable to enumerate USB device on port 1
[ 388.371034] usb 1-5: new high speed USB device using ehci_hcd and address 8
[ 388.485939] usb 1-5: New USB device found, idVendor=04e8, idProduct=681d
[ 388.485945] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 388.485950] usb 1-5: Product: SAMSUNG_Android
[ 388.485953] usb 1-5: Manufacturer: SAMSUNG
[ 388.485957] usb 1-5: SerialNumber: 1000ccb884cd
[ 388.598562] Initializing USB Mass Storage driver...
[ 388.600599] scsi4 : usb-storage 1-5:2.0
[ 388.600827] usbcore: registered new interface driver usb-storage
[ 388.600833] USB Mass Storage support registered.
[ 389.606354] scsi 4:0:0:0: CD-ROM Android UMS CD-ROM 00 PQ: 0 ANSI: 2
[ 389.607215] scsi 4:0:0:1: Direct-Access SAMSUNG GT-I9000 0000 PQ: 0 ANSI: 2
[ 389.608119] scsi 4:0:0:2: Direct-Access SAMSUNG GT-I9000 Card PQ: 0 ANSI: 2
[ 389.614956] sr1: scsi3-mmc drive: 0x/0x caddy
[ 389.617124] sr 4:0:0:0: Attached scsi CD-ROM sr1
[ 389.623734] sr 4:0:0:0: Attached scsi generic sg4 type 5
[ 389.629801] sd 4:0:0:1: Attached scsi generic sg5 type 0
[ 389.631604] sd 4:0:0:2: Attached scsi generic sg6 type 0
[ 389.647330] sd 4:0:0:1: [sdd] Attached SCSI removable disk
[ 389.656040] sd 4:0:0:2: [sde] Attached SCSI removable disk
[ 395.382511] TCP lp registered
[gescape@grendel media]$ sudo mount /dev/sdd/ /media
mount: no medium found on /dev/sdd
[gescape@grendel media]$ ls
[gescape@grendel media]$ cd ..
[gescape@grendel /]$ sudo mount /dev/sdd/ /media
[gescape@grendel /]$ sudo mount /dev/sde /media
mount: no medium found on /dev/sde
What I found online:
Froyo Update for Galaxy S Fries Internal Storage
by FABSH on DECEMBER 19, 2010 · in ANDROID
There are reports that Samsung pulled the update to Android 2.2
