Help Badly, badly, badly need help on my S6 Edge Plus battery life
ew0lx
Good day to all! When I first got my phone, I was very satisfied with its battery life. After the 2nd week, I decided to root my phone to install some apps that I need, but then decided to unroot it after 3 days. I did a factory reset and restored the data using Smart Switch.
After that, I noticed my battery went really bad. It would drain 30% of battery while I'm sleeping. I checked the battery stats and usually see Android System and Android OS suck up most of it.
As a first time Android user, it's hard for me to understand if this is normal or not. I've heard some users are having an issue with deep sleep, which I think is somehow related to my problem. I'll post some pictures below for you to understand my problem.
Your help would be greatly appreciated. :)
