OhMyPlinky
Hello. I started playing only 6 days ago. My trainer is level 11 and is still using the original type of balls. I'm noticing that when I try to capture certain Pokémon (Golbat, Ponyta, Nidorino) in the wild, my balls won't reach the target. I've spent 70+ balls on each without success, all the while thinking I'm doing something wrong with the throw. I have no problems capturing and throwing balls at the common, lower form Pokémon. Is my problem because I'm using lower type balls to try to capture evolved Pokémon? Or is it because their CP is too high for me to capture? I've tried capturing with AR on, with AR off, with using a berry, with controlled wipes and more aggressive swipes. Sometimes, the ball will just drop in front of me but most often, the ball lands just in front of the Pokémon. Twice, I was able to connect with the ball but of course, the Pokémon got loose. I've searched the web for others with this problem, but have only found one post without any solution to the problem. Please help! Thank you.
