Barren Lab_v3.8 apk - will not Load on my android TV
melani78
Barren Lab_v3.8 apk - will not Load on my android TV- it is installed , but when it Loads -it just quits when u press ok ? is this a bug or does only run on mobile phones ? I have the same version ""working"" on my mobile.
I don't know this app but sounds like a compatibility problem or other bug? Suggest you email the app developers about it, as maybe the can fix it.
What versions of Android are on your Android TV, and what on your phone or tablet?
thats why I posted on "Apps & Games" , its a game . Also I posted here because the Developer is not going to answer my questions because they are too busy making $$$ . My mobile is android 10 ,working - Android Tv is android 9, not working.
Sounds like that might be the problem then, the game could be incompatible with Android 9 or earlier. There's no way to force it to work, apart from either updating the Android TV or finding a version of the game that works with Android 9. Also the dev may have built it for mobile only, i.e. phones or tablets.
I presume this is the game. Their Play Store URL shows not found, which usually indicates that it was discontinued and withdrawn. Perhaps it wasn't making them enough $$$ ?
https://www.taptap.io/app/67239?hreflang=en_US
https://play.google.com/store/apps/details?id=com.renderedideas.barrenlab&referrer=utm_source=TapTap
