N
newbiezzz
Guest
Hey y'all,
I have a stupid question. I have an HP 7 android 4.1.2 and am having some trouble.everytime I try to delete either an app that's already on there or one that I've loaded I can't delete it. I can't even find the way to get to the menu the best I can do is get to settings but it doesn't give me the option of deleting hardly anything and even if I can delete something at some point in the search for somewhere I can see it pop back up but I can't find the actual file I'm not sure what to do if I should do a factory reset or what but I can also not get it to register the SD card and it says its running out of memory even though it has almost a half a gig of memory RAM just on the unit itself.
I've been all over the internet and I can't find what's going on any help would be appreciated its very very frustrating thank you very much
