Basic home screen tutorial
wyndslash
Android Expert
Hi! I've been drooling over the lovely works over at mycolorscreen.com, so I wanted to try to make my own, but I don't know how to start.
Does anyone know of a basic tutorial guide?
I've done a little themeing with just 3rd party launchers and such. Folder organizer or desktop visualizer also help with creating different looks. As far as a guide I found a few links that may help get you going in the right direction:
http://www.google.com/url?sa=t&rct=j&q=android%20homescreen%20tutorial&source=web&cd=3&cad=rja&ved=0CDYQFjAC&url=http%3A%2F%2Fblog.mycolorscreen.com%2Fpost%2F14014052079%2Ftutorial-how-to-make-your-android-pretty-extremely&ei=tmRTULTgHoe-9QSP0YGwBA&usg=AFQjCNGaesTyBrXcfhRxcYAg5rnIGPjEig
http://www.google.com/url?sa=t&rct=...1IC4Aw&usg=AFQjCNFBcV2ffW07SHcCLZQIqE65nOEEAA
http://www.google.com/url?sa=t&rct=...1IC4Aw&usg=AFQjCNEoeCmV0gjs5T0C9zUO7CEKk9C7jw
These should get you moving in the right direction. Also check out the mario theme thread link in my sig, theres a pretty good breakdown of how I got that look. Good luck, and please if you get stuck, just ask. We'll do our best to help you out. :)
thanks guys :) i think i just get frustrated too easily, haha.
i was trying to get this look yesterday: http://mycolorscreen.com/2012/08/22/happy-town/
the designer had uploaded the icons and such, but i think because of the resolution of my device (i'm currently using a rooted kindle fire), it looked kind of messy, and some of the icons didn't show up...
i also want a good calendar widget that i can display on my home screen that can also sync with astrid and google calendar...
The only Calendar Widget I have been able to find that syncs with Astrid is Android Agenda. And its not exactly a calendar since it only shows agenda view.
<a href="http://www.driveandroid.com/2012/09/how-to-create-theme-in-android.html">Create your own Theme in Android</a> Visit <a href="http://www.driveandroid.com/2012/09/how-to-create-theme-in-android.html">www.Driveandroid.com</a>
