I really can't speak except for the Droid. If you do a simple wipe, you usually don't have to redo things like entering your gmail info, etc. If you do a factory wipe, then it's like a new OS on your phone, so you have to start from scratch. Also, I think the installation method is relevant (on Droid, normally update.zip file or nandroid backup)...
