Bass Drop - Deep House
Download link
Deep house fans and producers can now rapidly perform bass lines, percussive loops, grooves and soundscapes with Bass Drop – Deep House. It's the ideal deep house production aid for budding and professional producers wanting to quickly jam ideas, create electronic sounds, perform live or chop sounds into their DJ sets. Speedily pick your drum loops and arrange the sample pads to create an arrangement, then perform a lead, pad or bass line with the built in synthesizer.
The app incorporates a keyboard synthesizer with a sound fx and drum loop sampler and loop station. It includes a large range of samples allowing the user to create limitless arrangements and soundscapes. The intuitive user interface facilitates multi-layer sound arrangement whilst offering brisk alteration of sample sounds and quick and easy adjustment of the synthesizer.
Each sample pad provides swift adjustment and full customization of pitch, volume and sample loop durations via the edit menu, as well as a choice of sample sounds including drum loops, percussion, grooves, percussion, bass lines, ambiences and special fx. The sound bank can be further expanded via in-app purchase.
The keyboard provides rapid octave shifting, pitch bending and five diverse synths that can be further rendered using the volume envelope adjusters.
The Matrix screen allows the user to swap the keyboard for 12 extra pads and arrange up to 24 touch triggered pads, massively increasing the combination of soundscape arrangements. Each layout can then be saved in up to 3 different banks.
Features:
-24 fully editable sample pads
-Hundreds of professionally produced samples
-Pitch resample all of the built in samples.
-Load and save up to 3 different sound bank layouts.
-Shape assigned buttons, for clear and straightforward use.
-In App Purchase to expand your sound library remove adverts and unlock functions.
Synth:
-Keyboard bass synthesizer with 7 synthesizer patches:
-13 key synth, sampled over 3 octaves with +/-12 semitone pitch bend wheel
- ADSR volume adjustment.
Sample Library:
- 78 drum loops, grooves, bass lines and risers
- 31 sound fx
- 67 percussion sounds
www.freshtouchmedia.com
Download link
Download link
Features:
Synth:
Sample Library:
- 31 sound fx
Download link
