Batteries and battery life.
Hi everyone. I have recently acquired a sony xperia P LT22i smart phone.
I really like the features and build quality, but I am finding that battery life is pretty darn poor. Even with battery saving mode enabled.
I have done a little googling and disabled one or two pointless apps that I don't use.
I am also considering buying a new battery, so I have done a little bit of homework.
Taking the back off the phone was easier than expected and after googling the part number (I love google), I am now a little confused about some of the information.
My phone has battery p/n AGPB009-A001 1265 mAh
after market batteries are available with both part numbers AGPB009-A001 and AGPB009-A003 with either 1265 mAh or 1320 mAh.
1) what is the difference between A001 and A003 ?
2) Is a battery upgrade really likely to make much difference ?
3) is there a battery to fit this phone with a much higher mAh rating
4) is there anything else I can do to help make the battery last longer?
Thanks for reading:)
