Battery 100 percent charge notification app
chunker
I've tried numerous battery apps that will give a audible alarm when the charge is complete. They all seem to work well and alarm me as they are supposed to. However it seems that on all of them I can't find a way to turn the sound off. It just plays and plays and plays. I don't have the option to repeat enabled and the only way I can stop the audible is to go through the application manager and force a stop on the app. Can anybody recommend an app that will give the alert once and stop, or even have a stop alarm button that works? Thank you for any help anybody can give me.
Success! I finally found one that is even beyond my expectations. You can find it here:
https://play.google.com/store/apps/details?id=com.pextor.batterychargeralarm
It has all kind of options to set it up. I really like the option to add minutes to your charging time before it alarms. That way you get the high end of 100 percent and not the low end. Plus if you go the manual route it will sound once if you don't have the repeat option enabled. It also includes many choices for your alarm tone and a disable button if you choose repeat. In the end I choose the automatic option that turns and enables the alarm mode when you plug your device charger in. It repeats the sound but does turn off the moment you unplug the cord. It will also give you a notification of how long the charge took if you have that option on. I'm really not interested in the anti theft feature and have that turned off. I'm sure it works just as well. Hopefully this app will work for others as it is for me.
