Battery Charge Percent.....92 Max?
Tyberg29
Do I was just charging my G1, and the green light came on at 92%....is it done? Is it normal for the G1 not to go up to 100? Or is this just the early stages and will it change and go all the way up after a few charges? Thanks.
The phone can't actualy tell how full the batterie is, what it senses is how much current is going into and out of the batterie, and with that info it can tell. The green light comes on when it thinks its pretty much fully charged. As with most rechargable batteries, the last little bit always takes a little longer to charge (which may only be a few mor minutes) but basicly the phone is saying "i'm pretty much ready".
I'm thinking you need to let it go to 100% but maybe let it die completely then charge it to 100% runs to corner!
