I recently updated my Samsung Galaxy S5 Neo to Nougat 7.0. When I charge the battery, it reads 100% but as soon as I unplug the charger it reads 98%. Why does this happen and what can I do about it? I already wiped the system cache.
Hey i had the same issue as you. But i am on marshmallow. What i did was removed and replaced the battery and placed it on charge again. You dont necessarily habe to charge your phone till 100% keep the battery level at a low of 10 and high of 90 so charging it till 90% is fine...
Ok so for the removeing and replacing of the battery do it for three times. Remove it replace it then boot up when the screen turns on remove it then repeat the process for 2-3 times.Then the percentage should drop or increase.
