battery charging pathatic
  • Start date Start date
A
Android Question
Guest
charging is pathatic. specially if the battery low level , if above 90% it is not bad.
one hour 2-3% only . how to fix it?
i heard most of this galaxy s3 same problem?
what could be done on this?
It's hard to say without knowing more information. If it is this slow when using a mains charger and the phone is just sleeping with the screen off then something is definitely wrong - most S3s are not like that! On the other hand, if you are using USB or a 1mA car charger and playing games or GPS navigation at the same time that's not surprising at all, as you'll be using as much power as is being delivered to the phone.
If the problem is with mains charging with the phone inactive, I'd suggest registering so that you can post the question to our S3 forum. That way a lot more people will see the question, and you'll be able to answer their questions and so find a solution quicker.
