PrinceOfDorne
I noticed that after a 10-hour standby with no application running, my battery went down from 39% to 26%. Normal or not?
While I don't have a S7, I don't think that drain (on marshmallow) is normal.
I charge my phone (Nexus 6) just before I go to sleep, and it stays off the charger (disconnected from WiFi/Mobile data) till morning. about 7-8 hours. When I wake up, my phone is usually between 97% and 99%. This is repeatable - same results everyday.
(I'm not using a custom ROM or kernel etc)
As for the 13% drop in 10 hours, I'd suggest checking to see what app is using up battery. Charge your phone up, and leave it idle overnight. In the morning, go to settings/battery and see what the top battery draining apps are.
> If you find Android system or Google Play services in the top few, reboot your phone and see if that helps
> If you find third party apps in the top few positions, you may want to restrict background data for those, or reduce sync frequency, or look for alternative apps)
And what about data? And how is the phone set up? As mentioned by the poster before me, what does the battery stats say?AOD is always turned off.
