D
Deleted User
Guest
Hello all,
I've researched a lot about my issue on the forums, but I was hoping that some specific details about my issue might help me find a solution:
Verizon GS3 White, purchased at launch, 4.0.4
(I'm trying to get my android file transfer working on my mac, so I'll upload screenshots of BetterBatteryStats and the Battery screen when I get that going.)
My battery stats today are pretty typical of what happens on a regular basis: 12h 30m and charge is at 5%(!)
Cell Standby 34%
Screen 20%
Chrome 12%
Android OS 8%
Wi-Fi was off all day, no BT, no sync, light use of GPS (15 min or so), and moderately-light use of phone for mostly browsing and e-mail. That seems like REALLY bad battery life. I can't figure out what's up! I'm also running one-touch battery saver which appears to basically turn off selected functions like the ones listed above.
The Kernel Wakelocks using BetterBatteryStats look something like this:
"bam_dmux_wakelock" 22.8%
"deleted_wake_locks" 1.5% (These two usually top the list in some form or another)
"smdcntl0" is often on there too
The drain seems to be exponential. For example, about 3 hours ago, I checked and the phone was at about 45%. When I looked at it again, without using it at all, it was all the way down to 15%. All services were still off except for Mobile Data.
I am just hoping that someone has some initial advice or a certain thread I haven't seen that you could point me to. Thanks much, Nate
Cell Standby 34%
Screen 20%
Chrome 12%
Android OS 8%
Inside Phone info, select Battery information. You'll get lots of interesting information about the battery such as the reported health, current voltage, and temperature.
