Battery drain problem
Hello, i have a 7" wm8650 and I flashed uberoid and now it runs much smoother.
I had this problem right after i got it (3 weeks ago) and hoped flashing will solve this problem too, but unfortunately it didnt...
So, when I charge battery full, it reads 100% but right after plugging charger out it shows 90% and then after few minutes it falls to around 70% and then it drains slowly, normally I think...
I tried battery calibration app but no luck...
Any suggestions?
How long should battery last on this device anyway? I can get around 3 hours of active use...
Thank you
I have problems with my battery as well, but I do know that I had overcharged the battery one or more times. I have not been able to recalibrate the battery but it drains faster now than when it was new.
Any suggestions?
Thank you
