Help Battery Drain
Probably an app causing a wakelock issue. Check your battery stats if an app seems out of the ordinary
Did you check your battery monitor?
I noticed my screen using like %70 of battery, that's pretty weird. Then I realized screen was not timing out after I put the phone down..
It was most likely an app causing havoc. Just pull the battery next time. I have had it happen a couple times before on my phone. Usually after installing a new app.
