I mean from night to morning, about 12 hours.
The battery is draining about 20-25%, This is a lot because my previous iphone [iphone 4] drops 1% or 2% (or sometimes it didn't loss anything).
Any help ?
I am using live wallpaper on both home and lock screen (although the screen is off) but i don't think it is causing this.
Thanks for answering.
Hi bo waleed, Please check previous topics about battery problems. Anyway I will re-post my previous comment:
"There are many options that you need to consider. For example 3 nights in a row I have left it around 00:00 at 100 % battery and in the morning at 07.30 it is usually on 97% or 96%, which means that it is great, considering that this is Not on airplane mode or anything else.
I will give you some of my settings:
Settings:
*Screen mode - Standard
*Auto adjust screen power - on
*Brightness - Manual- 25-30%
*Power saving - CPU power saving on + Turn off haptic feedback
*Location services - Everything off
*Motion - everything On
*Wallpaper - Live or still - make sure it is dark or black - saves battery
*Developers Options: Limit Background processes : Standard limit.
Use advanced task killer program to kill all applications after full charge just before sleep, ensuring that you do not have running applications."
Edit: Last night I lost 1% of Battery. I left it at 88% at around 23.50 and woke up at 07.40 and it was on 87%. (true).!
I do not know if I'm lucky or something, but my recharge time is unbelievable (my opinion). I have checked and my phone recharges about 50% in 1h30min maximum, from the normal charger which goes in the plug.
If this helps you do not forget to press the "like" and/or "thanks" button.
