battery draining help !!!!
I have a Galaxy SII which I love. However on a couple of occasions my battery has completely drained without being used at all. I have found what may be a common denominator - on the two most recent occasions I have used it as a Sat Nav in the car whilst having it plugged into the in car charger. It has been charging and worked really well. Then when back from my travels and in the office the battery has just drained !!!! Any ideas anybody ???
Hello and welcome to Android Forums. :)
Battery issues has been one huge problem for almost every smartphone users. If I have a "full-proof" solution I would definitely not be on here writing this.
However, as bad as these batteries are..I don't think it should be draining that fast. First thing you should do is to replace that battery. You might just have good battery gone bad.
Also, check inside your device's support area for some tips and tricks on your device.
There are a few carriers who have the Samsung Galaxy S2 - So I've linked all variants of your phone. Just choose your phone from the list.
Samsung Galaxy S2 (AT&T) - Android Forums - (AT&T)
Samsung Galaxy S2 (T-Mobile) - Android Forums - (T-mobile)
Samsung Epic 4G Touch - Android Forums - (Sprint)
Samsung Galaxy S2 (International) - Android Forums - (International)
Samsung Galaxy S2 Skyrocket - Android Forums
Samsung Galaxy S2 Skyrocket HD - Android Forums
I hope this place will be of great help to you.
