Battery life app that does 1% increments? (Droid X)
Zumi
Does such a thing exist? I've only come across ones that show the remaining battery life as 10% increments and was looking for something more accurate/exact. My Evo had this ability, but my Droid X doesnt. :(
I think that's a Droid thing. It only reports batter in 10% increments.
It is the phone's driver that only allows 10% increments. I have had this in many phones. In Windows Mobile I even changed the driver for a different one that allowed 1% increments, but I doubt it can be done in Android.
Batteryminder will do exactly what you want. I have been using the free version for over a month and haven't looked back.
Batteryminder
by Rollerbush
10,000 downloads, 818 ratings (4.4 avg)
Free
All of these battery widgets get their readings from some core source within the phone. Meaning, all they do is read the info that is already there.
So the only accurate reading you are ever going to get is in 10% increments because that's how the droid core reports it (because that's how motorola programmed it). And that's why the HTC phones report in 1% increments.
What does it matter? Worrying about whether the remaining battery is 18% or 13% is like a 30 handicap golfer being concerned over not knowing if they have 190 or 187 yards to the pin.
those 3 yards can make the difference between club selection.....
The "fact" that it does it in 10% increments is BULL.
From the time it was new... till today it gave me an exact number. One battery app I downloaded changed something. I am searching for the fix.
attachment.php
You apparently missed my point altogether. While a 30 handicap may think it changes his club selection, they could likely choose any one of 4 and end up with a similar result.
Very cool. Then fix it.
Sounds similar to how the Samsung Moment was modded to allow it to report in 5s instead of 10s because the detailed scale was inaccessible to widgets. That might be a good place to start your search. Good luck :)
PS, very convenient that today it suddenly stopped working... again, good luck figuring out how a widget that simply mirrors info has apparently managed to change your phone's battery coding.
Maybe it is internal to the widget or app. See one (Battery Left) shows the exact number the others the 10% range.
attachment.php
Battery Left is estimating how much battery is left. It's not a true/actual reading. How accurate it really is, I don't know. Since the OS doesn't report the programs in 1% increments, there's no other way it could be doing it.
I guess you run the battery up and down a few times and it kind of figures out how much juice it takes and then extrapolates from there.
I really like the way BattStatt looks, shows the same percentage as battery life, makes it easier to see how quickly my battery is charging.
Do these widgets eventually add on the % numbers? I just installed Battery Left and I'm not seeing anything yet. I read here it has to annalyze the battery up and down a few times, but does it then add a % number somewhere (like on the battery itself)?
Thanks!
