Kathryn Francis
Hi everyone, I'm new to Android after being an Apple user for 7 years!
I took the plunge and upgraded to the Samsung Galaxy S7 and must say I am loving it!
However ....
My battery is being drained far to quickly for my liking. It goes on Charge overnight, I'll unplug it roughly around the 7am mark. By 12pm I am having to charge it again as it's under 50%.
I've tried the following to help preserve it ...
> Low Power mode is enabled constantly
> Mobile Hotspot / NFC / Sync / Always on Display / S Finder are all OFF
> I've turned the LED notification off
> Screen Brightness is set to just under a 1/4 of the bar
> As soon as I stop using my phone, I close the app completely so nothing is running in the background.
Looking in the Battery Usage section I have the following for the past 8 Hours:
Android OS - 29%
Cell Standby - 19%
Google Play services - 17%
Screen - 13%
Android System - 7%
Voice Calls - 6%
Device Idle - 2%
Maps - 2%
I have no idea why Maps is even showing on there as I haven't used that since having the phone and can't understand why the Android OS is using so much of the battery.
Any Ideas? Is there some other setting I can change or do I need to return the handset?
Thanks
However ....
Android OS - 29%
Cell Standby - 19%
Screen - 13%
Android System - 7%
Voice Calls - 6%
Device Idle - 2%
Maps - 2%
Thanks
