This is my second ZMP and the battery life was the same on the first one. I we could only get a custom ROM that would optimize our phones.And OP if you keep getting battery life like your screenshot, get it replaced, the battery lasts a lot longer (generally)
How were you able to do that since it's baked into the phon.. Al I did was disable itI just got rid of the Facebook App which was a big battery sucker. I can still use face book through my browser and still receive notifications. Battery life has improved. I'm looking to identify other apps which may be affecting battery life.
Would the facebook app show usage? There are days,like today, that I don't use that app much. But the battery still sucks.I just got rid of the Facebook App which was a big battery sucker. I can still use face book through my browser and still receive notifications. Battery life has improved. I'm looking to identify other apps which may be affecting battery life.
Eeks. That doesn't look very good. Especially seeing that there aren't any obvious improvements you can make based on what apps/functions are using the most battery. Curious if other people are having a similar experience.
Any other Zmax Pro users can screenshot/share their battery usage?
How were you able to do that since it's baked into the phon.. Al I did was disable itonematI just got rid of the Facebook App which was a big battery sucker. I can still use face book through my browser and still receive notifications. Battery life has improved. I'm looking to identify other apps which may be affecting battery life.
I know, but I can't figure it out. This is my second Zmax Pro and the other one was the same.What the **** something is wrong with your phone lol.
I see you have a custom status bar, maybe the screen overlay is buggy and it's draining battery even when the screen is off, I don't know if that's possible, I'm just making an inference. Maybe try turning the custom status bar off for awhile and see if it helpsSo I download the gsam app and this is what it comes up with. My display is low. Does the discharge while off mean that it's draining even when its off?
I think that it was doing it without the bar. But I will turn it off for a day to see what happens. ThanksI see you have a custom status bar, maybe the screen overlay is buggy and it's draining battery even when the screen is off, I don't know if that's possible, I'm just making an inference. Maybe try turning the custom status bar off for awhile and see if it helps
I hope it helps. Which variant do you have?I think that it was doing it without the bar. But I will turn it off for a day to see what happens. Thanks
Metro on B12I hope it helps. Which variant do you have?
Why not update to B14 and see if it helps?Metro on B12
